Today son Thomas and I had a jolly day out with the local VMCC section, him on the SQ4 and me on his Interceptor for a change.
I now know that the SQ4 puffs a bit of smoke, a tiny bit, when you crack the throttle open and when you shut off. It's not enough to worry about, but it's probably worse on the timing side.
I have a feeling there was a post about this a while ago.
It's had new rings, valves and guides in the last 3000 miles and is bog standard apart from the Morgo.
Little puffs of smoke
Re: Little puffs of smoke
hi i think it is a little bit of oil going down the valve guides
Me too. No seals, flat topped guides, inevitable really.JohnnyBeckett wrote: ↑Sun Aug 20, 2023 8:42 pm hi i think it is a little bit of oil going down the valve guides
I put Teflon washers on my Mk1's inlet valve stems, to act as little umbrellas. So far, no smoke from the exhaust; but then it has done only 200 miles since fitting them. So I may be celebrating too soon.
Cheers Chris.
Cheers Chris.
Good thought though. We're they tight on the stems?Chris Sealy wrote: ↑Sun Aug 20, 2023 10:50 pm I put Teflon washers on my Mk1's inlet valve stems, to act as little umbrellas. So far, no smoke from the exhaust; but then it has done only 200 miles since fitting them. So I may be celebrating too soon.
Cheers Chris.
Yes, they are tight. They sit at the very top of the inlet valve stems, as most of the valve stem disappears down inside the guide at full lift. I bought undersize {metric} Teflon washers and trimmed the inside diameter to a chamfer, using a sharp knife.I then shaped them on a tapered stick. I believe that the main route, that the oil takes onto the valve stem, apart from mist, is via the gap between the collets; therefore there is room for experimentation here, with a modern high temperature silicone sealant. I may try this at a later date, if my little umbrellas fail for any reason.
The late Bob Brassington used to assemble his collets with high temperature silicone for this reason.
