Ariel Twin KG / 1948 valve clearance
- Karol Burger
Hello my friends. A week ago he discovered that my gasket under the engine head was damaged. I am currently trying to fix this and need your advice. After I replace the gasket and take the entire engine apart, I will need to adjust the valve clearance for the lift rods. What is the appropriate valve clearance for the KG/1948 model
Re: Ariel Twin KG / 1948 valve clearance
Hope this helps
- Karol Burger
Thank you Vincent. I will translate it into Slovak and use it during assembly. You helped me a lot. It's hard for me to find it when I don't know the language.
Karol
If I understand this topic correctly :
viewtopic.php?t=13636
Tappet clearance .002" (both) unless you have a later (as used after 16/2/1952) camshaft fitted in which case 005"(in) and 008"(ex).
Ak som správne pochopil túto tému:
Vôľa zdvihátka 0,002" (obe), pokiaľ nemáte namontovaný neskôr (ako sa používa po 16/2/1952) vačkový hriadeľ, v tomto prípade 005"(in) a 008"(ex).
- Karol Burger
Thank you boys. We managed to assemble the motorcycle and tomorrow will be the first test ride. Looks good so far
- Attachments
- 20230817_203051.mp4
- (2.65 MiB) Downloaded 17 times
Users browsing this forum: Bing [Bot] and 19 guests
