VB return pump fail
Posted: Wed Jun 07, 2023 9:05 am
On route to a New Zealand Ariel rally a couple of months ago, the VB return pump failed approx 30 miles from my destination. I did not detect anything amiss until I arrived and noticed a growing puddle of oil under the bike.
In that distance it had pumped about half a tank of oil onto the road and all over the rear of the bike. It had also filled the magneto with oil and yet the old girl did not miss a beat. While it was idling, there was oil peeing out of the points cover !
I stripped the pump etc and cleaned everything out as best I could while at the motor camp accommodation ( found nothing at all in the return pump; perhaps a slight mark on the ball bearing seat, but no dirt etc) and did complete the rally the following day without problems.
On return home, I found that, not only was the mag full of oil, the fabric wrapped dynamo field coil was absolutely saturated and proved impossible to get clean.
I guess a positive is that I now know that my feed pump works really well
I am now wondering if I should remove the rubber washer that is between the timing case and magneto so that if the return pump does fail again, at least it may be less likely to contaminate the magdyno.
Cheers,
Bevan
Cheers,
Bevan
