DKXHA distributor wanted for Mk 1 Square four
Posted: Tue May 16, 2023 4:29 pm
by GregP
I’m thinking they are as rare as rocking horse droppings but just in case
Greg
Re: DKXHA distributor wanted for Mk 1 Square four
Posted: Tue May 16, 2023 6:18 pm
by Paul_Linden
Yes, original DKX4A distributors from a square four are few and far between, but do not despair as you can use one from an Austin 7 which are slightly more common. You will need to fettle the advance retard and change the gear at the bottom. Sometimes they have a little oiler fitted on the drive shaft.
Posted: Tue Jun 06, 2023 8:31 am
by SiegfriedSereinig
Hello
Hello
You can use this one.
An adapter ring must be rotated.
best regards
https://www.rackkatrac.com/tete-de-dist ... ge-sev.htm
