Re: Mechanical lock up - w/ng
Posted: Sun Feb 19, 2023 7:03 pm
Thanks Paul, that is a possibility, but today, I shimmed the gap between rocker box and exhaust lever out to 0.160", put the rockers back on and was turning the engine over very slowly with my finger on the exhaust tappet adjuster - ouch! Every now and then the valve must be sticking as it comes up with some force, hits the tappet adjuster (hurts my finger) and makes the familiar metal clang I have been referring to and calling a mechanical clang for ages.
So the question is why does the valve stick - I am guessing a bent valve stem?
If the valve is sticking, this must cause slack between the pushrod/rocker and pushrod/cam - I wonder if that is what occasionally causes a mechanical jam?
