Hi, I am having 1930 LF/LB brake pedals cast 5401-30 or E8/1117 If you need one let me know.
I notice the 29 pedal is a different no 5401-29 or E8/517, do you have one or know the differences????
I am also having footrests 5383-29 or E8/562 cast although these are the same as the 500/550 29-on. If you need any let me know.
The footrest supports are shorter on the 250s 5376-29 or E8/602 but longer ones can be reduced.
Later I will be ordering 30" speedo cables 5227-29 or Z/6 for my 250s
I don't have a cable to crankcase bracket 5216-29 or A6/613 to copy (same as on sloper 250/350) A drawing or photo would help.
Also am looking for 4 mag sprockets 1926-29 or A6/369 to suit Lucas MC1 mags ( much further out from the mag than other Ariels)
And 1 more mag sprocket for cam end 1921-29 or A6/368. (smaller hole/taper than other Ariels)
I may have some made if you are in the same boat as me. Jim
1929/30 LF/LB 250 parts
Re: 1929/30 LF/LB 250 parts
Jim,
My 1929 LF is missing footrests, brake pedal and timing chain sprockets amongst
other items like the timing cover and the engine sprocket and shock absorber so
count me in.
The 1929 brake pedal is the same taper as the 1929 500 but the pedal angle seems
to be different. Quite what the difference is between 1929 and 1930 brake pedals
is I'm not exactly sure but a quick look look in Dave Barkshire's excellent Black
Ariels book suggests that the arm connecting to the brake rod is significantly longer
for the 1930 models.
count me in.
Good idea Will, I will have a look at the original photos in Dave's book and try to spot the difference.
