Hi all,
The outermost threads on one of my tappet inspection holes (single cylinder OHV engine) are stripped so the only way to get any retention is to leave out the fibre washer to let the cap sit deeper and just seal with silicone but this always ends up leaking after a few months. Has anyone else found a solution - like do some caps have more thread than others?
Graham
Partially stripped rocker inspection cap threads
- john.nash
Re: Partially stripped rocker inspection cap threads
Peter Kemp (single spares) had some s/h rockerboxes.
He also has some "oversize" caps.
- keith.mettam
Hi Graham,
I bought a new cap from DraganFly a couple of years ago and it had a longer threaded portion than the one I was replacing. The following link (which you may need to copy in a new browser window if it doesn't work) shows an image of their caps:-
http://www.draganfly.co.uk/shop/pd-1895 ... goryId=146
They could be worth a ring if Peter Kemp is out of stock or can't help you.
All the very best,
Keith Mettam.
All the very best,
Keith Mettam.
Users browsing this forum: Majestic-12 [Bot] and 24 guests
