Johnny,
Are you thinking of ‘Nikasil plating’ as found in BMW cylinders ?
It’s not a thick coating so wouldn’t be good for building up a bore. Was it a spray welding process you used ?
VHA cylinder liner ?
- Bob.Murphy
Re: VHA cylinder liner ?
hi Bob the BDA cosworth engine block comes nikasil plated new, and when the bore was worn i sent back to cosworth and they did it back to standard i think they spray welded it like we do to crankshafts, not sure if it was done at cosworth or sent over to Holbay Engineering who done a lot of design and development work for them , and their own engines ( a new engine block today i think is about 10 grand ) if you can find one
I found a shop that will push the old liner out, measure as pr Westwood requirements
A friend of mine with his Ducati single racers he also pins his liners in.
Ian
Ian
It will be interesting to see just how easily or otherwise the liner comes out.
When I had one linered some 20 years ago the liner had to be machined out
in the end.
in the end.
