wire loom- sq4-1939
wire loom- sq4-1939
HI, I have started to wire my sq4, but the wire diagram that came with the wiring loom is pretty hopeless, and the layout is strange as well. On the loom I bought, I have to connect 2 wires at the voltage regulator, normally that is done a No3 in the headlight, and there is 5 wires connected at the ammeter, I have only worked on bikes that has 2 at the ammeter. Does anyone have a correct wiring diagram to a Ariel sq4 from 1939?.
Re: wire loom- sq4-1939
That is the correct diagram for that loom, assuming that the loom also came from Draganfly. The diagram shows 3 wires to the ammeter and 4 to the regulator, all quite standard for most if not all Ariel four strokes. Clearly some confusion.
Yes,you are right, I have only worked on old Sunbeams
