Page 2 of 2
Re: Fuel tank filler cap
Posted: Mon Nov 21, 2022 3:09 pm
by Bob.Murphy
Dave,
The hole in the cap spindle is for a security chain that goes into the tank with a heavy wire bridging piece on the end.
With a clevis attaching the chain to the spindle you won't need the lower locknut
Having the filler cap dangling on the outside of the tank might not be good for the paintwork though.
Posted: Mon Nov 21, 2022 4:40 pm
by Chris Sealy
Hi Dave. I am currently rebuilding a basket case squariel. As Will says, the vent hole is much closer to the other end of the threaded shaft. I wonder if the hole shown in your photo is where someone has drilled to fit a split pin, instead of a lock nut. Have you tried dribbling some thin oil down the vent hole, from the top, to see where it comes out?
Posted: Mon Nov 21, 2022 8:18 pm
by will_curry
I agree with the idea of a security chain to prevent the filler cap getting
lost. Below should be an image of the screw from my filler cap:
It's not the clearest but you should be able to see both the size and location
of the vent inlet. The outlet is via a hole in the centre top of the screw.
Posted: Sun Nov 27, 2022 11:30 am
by Dave Fearon
So having taken the fuel cap apart completely I can see that there is already a hole drilled near the top. I have taken off the cork washer as I cannot see any use for it, and it is disintegrating into the fuel tank. This cork washer seems to have been supplied with the Indian made version of the petrol cap which is no longer available from Draganfly. I have ordered a rubber washer to seal the cap. Thanks for everyone's input. Dave
Posted: Tue Nov 29, 2022 5:30 pm
by dennis.t
On my Indian replica fuel cap the hole shown between the nuts is not a vent hole but one for a split pin. They used only one nut with the split pin to stop that nut coming off the threaded shaft.
Dennis
