Arrow Gearbox
Posted: Sun Nov 13, 2022 7:09 pm
I am rebuilding an engine from several parts and all was going well until I started assembling the gearbox. The idea was to rebuild it on the workbench and check its operation before putting it in the frame. I have rebuilt the gearbox and attempting to check it. First concern there is some lateral play in the main shaft when in neutral? but not when in first gear. With the end covers on gear selection is difficult neutral and first select ok but I am finding it difficult to select the other gears? Is the problem because the engine is not running? Any advice appreciated.
