Moments like this make it all worthwhile.
Moments like this make it all worthwhile. The first time my '54 VH500 has run since I bought the engine in bits.
Still some way to go but at least I know it runs.
Dennis
Dennis
- Attachments
- EDF0261B-F019-406C-AAAC-66DF4CFB1562.MOV
- VH500 fires up
- (29.7 MiB) Downloaded 137 times
1955 VH500 alloy head
Re: Moments like this make it all worthwhile.
Second attempt to load the short video!
Dennis
Dennis
- Attachments
- 6B9452B1-4832-424F-8315-8A096DA9E683.MOV
- VH500 fires up
- (29.7 MiB) Downloaded 105 times
I can't seem to upload the video - sorry.
The subscript states that: "The video is not uploaded yet."
Does the Forum support videos in a post?
Dennis
Dennis
Both videos certainly seem to be working here .
Its always a nice feeling when the engine first starts.
Well done.
Well done.
Will,
Thanks for confirming that the video works. It seems I am the only one who can't view it!
Dennis
Dennis
The video certainly works here as well. The bike sounds fine, but the finish on the petrol tank needs some work, particularly the gold lining!
The next step is to finish the bike, then run it enough to iron out the various snags, then go on and try your best to wear it out! The last bit is the best.
Well done and keep up the good work.
Paul,
I have a sound tank but the paint needs some work. Also, my lawnmower will need its tank back by the Spring.
I was pleased that the ignition timing was just about right first go but there does not seem to be much range in the mag lever between minimum and maximum advance. Perhaps there is enough as the engine runs and revs fine.
I still have a number of items to buy such as exhaust pipe, silencer, wiring harness, battery, regulator/rectifier, rear chain, horn, horn push, rear light, rear light switch, footrest rubbers, rear shocks, chain guard, etc., so I hope Santa can carry that lot.
Dennis
Dennis
- robjameson
Hi Dennis,
What great progress, always nice when you fire them up for the first time.
On your list of stuff required, make sure you get a regulator - you don’t need a regulator/rectifier as the dynamo works in DC, you only need it to regulate the voltage (unless you’ve upgraded to an alternator?). I can highly recommend the AO regulators available from Paul Goff among others.
Good luck with the rest of the rebuild!
Rob
Rob
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
Hello Dennis,
Looks and sounds great, well done, bit more fettling and you will soon be out enjoying that lovely bike.
Colin
Colin
Rob and Colin,
Many thanks for your kind comments.
Good point about the regulator Rob, I have only had alternator bikes previously so I did not consider what I needed for a dynamo. Actually I have not got around to thinking about the wiring and electrical items yet as getting the engine running was my priority. I have 'motored' the dynamo since fitting a new field coil and armature and reconditioning the dynamo generally so I am hopeful that the dynamo works.
Dennis
Dennis
