Bike history
Posted: Mon Nov 07, 2022 3:49 pm
Hi all, I'm just fixing an oil leak that appears to be coming from the soldered joint on the head feed, and decided that whilst I was doing that I would perform an oil change. I also decided that removing the oil tank to give it a good flush, would perhaps allow me to tackle a few dents it exhibits too.
The point of this post though is now I can clearly see the gearbox number, I was reminded to look the code up on the Draganfly website.
Now, some of you may remember that I have known this bike for several years, the previous owner having brought it back from India, probably over 20 years ago now. He had it languishing un-used for many years, and I was tasked with getting it running again, and registering it for him. This we duly did, though it was clear that it wasn't as factory spec, wearing a W/NG frame and engine number, but sporting tele forks and many other departures from standard.
Anyway, long story short, it was pointed out by the eagle-eyed on here, that it wasn't a W/NG frame, the rear tubes not giving the increased ground clearance.This of course made sense, the only genuine W/NG part is the bottom half of the engine, and clearly someone long ago has tampered with the frame number, matching it to the engine. I looked up the gearbox number, and it is indeed from '46 (G7 code), and was fitted to either a VG, VH, or VB. Would the actual number be in the despatch records? Ie, can I positively identify what this bike was when it left Selly Oak? Currently, to be clear, it has a 350 engine, and the cycle parts appear to be De-Luxe rather than Red Hunter, so I'm guessing that narrows it down to VG or VB.
Cheers, Tony.
Cheers, Tony.
