Page 1 of 1
WHICH RECTIFIER FOR LEADER
Posted: Tue Oct 25, 2022 8:43 pm
by PaulWoolley
I need a RECTIFIER for my resto.. should it be a reg/RECTIFIER or is the cheap £7 solid state RECTIFIER any good. Thanks paul
Re: WHICH RECTIFIER FOR LEADER
Posted: Tue Oct 25, 2022 10:36 pm
by Roger Gwynn
The solid state ones work very well but they are only a rectifier and not a regulator. the combined regulator and rectifier is a better system as it controls the rate of charge to the battery based on demand instead of guessing it using the light switch!
Posted: Tue Oct 25, 2022 10:56 pm
by will_curry
It's not uncommon to find corrosion damage to the bodywork around the
battery carrier caused by the battery being overcharged and spraying acid
over the works. I'll be using a combined regulator and rectifier when I finally
get to that stage with my Arrow.
Posted: Wed Oct 26, 2022 6:16 am
by ian williams
your best bet would be an AO services A REG 6 , see links below .
they do say to use minimum 5ah battery but the leader/arrows use bigger than this anyway .
these units use very very little residual current in the sensing circuit , so wont flatten your battery very quickly , i have the dynamo regulator they do and it only draws 0.15ma , which would take a couple of years or more to flatten the 12ah battery , i will put the A REG 6 into my leader and cafe racer .
i did previously have a wassell make regulator in my NH but it flattened battery in 2 days !! and have now swapped to the AO services one and my battery stays up all the time at present however long it is left [still connected ] .
if you have a leader with indicators fitted and are out riding one day and you find it misfires when the indicators are on , you can bet the battery is either not much good anymore or its pretty much gone flat , sometimes may be idea to carry a small 6v sealed battery in the toolbox or your pocket just in case .
regards, ian
http://www.aoservices.co.uk/a_reg.htm
file:///C:/Users/hp/Downloads/a-o-services.pdf
Posted: Wed Oct 26, 2022 3:58 pm
by paul.darnell
I recommend using a combined regulator/rectifier for all the reasons above, plus you can fit an AGM battery without fear of damage and LED lights which are happier with a regulated supply. I use an Elektrex one which can be 6V or 12V, depending on whether you snip a certain cable or not. It easily fits in the same position as the standard rectifier.
https://www.electrexworld.co.uk/acatalo ... ml#SID=439
Posted: Fri Oct 28, 2022 9:45 pm
by PaulWoolley
Hi. Thanks for the advice, I will go with the A reg 6
