Valve cap gaskets for S Valve Ariel
Re: Valve cap gaskets for S Valve Ariel
Charvey - you should be contacting the current spares man, not the old one! His name is now Allan singlesspares@arielownersmcc.com
Hi All, I contacted Allan and the only valve cap seals are too small which is a shame but I managed to get some alloy washers the right size which I had to trim down a bit but they are 1 7/8" internal size and will try them when I get the bike going, am still waiting for some bits to try it down the road it seems to have been restored quite a few years ago then left for about 20 years+ the number sold off but it has a good number instead, it had been stood so long that the grease in the wheel bearings had turned to oil which covered the linings and the rear bearing had broken up the outer bearing had broke up when fitting I think and the inner had run out to make a right mess but cleaning up and a pair of bearing from my very limited stock sorted that out, it's a good job that the bearings fit quite a few bikes over a long time Regards Clive.
Users browsing this forum: Ahrefs [Bot] and 12 guests
