Wheel offset
kevin.eastwood
Wheel offset
Post by kevin.eastwood »
Hi All, I am in the process of re building a rigid NH 1952. Bought rims & spokes from Drags but have no info regarding offset.I only had hubs to start so nothing to measure from. Drags catalogue says central between the spoke flanges, but can anyone confirm or otherwise please before I commit myself.
Kevin (4428)
Presume the wheel is 20". Can you measure the exact rim width. (external) I probably have an original but rusty wheel that I can measure. Don't think the rim is central between the flanges but central in the forks. Nev
kevin.eastwood
Dont have the rim-its on the way from Drags-WM2 x 19". Kevin.
might as wel wait till you have it. Then get it exact. Nev
brenton.roy
Post by brenton.roy »
Front, rear or both?
kevin.eastwood
I need both wheels offset please
adrie.degraaff
Re: Wheel offset
Post by adrie.degraaff »
Front 33mm, rear 56mm, measured from small side of hub to rim side.
Sorry for the delay, was not near the motorcycle.
kevin.eastwood
Thanks Adrie-not been near comp for last 3 weeks. been touring Ireland on 2 wheels
Users browsing this forum: Majestic-12 [Bot] and 30 guests
