"Mainshaft, gear side", 1954 - 58, part no: 1150-35. - New or used in good condition.
Also lh thread nuts.
- As on photo:
Petri Järvinen
WTB: - VH500 1954 Mainshaft RH.
- Attachments
- 1150-35U-600x397.jpg (85.5 KiB) Viewed 747 times
2 X Ariel VH500 1954, Indian Scout 101 750cc 1929.
- john.nash
Re: WTB: - VH500 1954 Mainshaft RH.
Is this the same?
Hiw can I tell as there are no numbers on it
No John, it isn't the same. Look at the large end of the taper which goes into the flywheel. Yours has a step there which makes it the weaker type. The one wanted has no step which is the stronger Red Hunter type.
There are 3 versions of this shaft, one of them has the holes in a different position, check carefully before use!
- Thanks for the clarifications, the axle is still in search...
PJ
PJ
- Still looking for mainshaft axle and nut; 9/16" 20 TPI lh .
Hello.
- Thank you all for your interest, the parts have been found in Denmark.
