Page 1 of 2
primary chain trouble VH 500,
Posted: Sat Sep 17, 2022 10:36 pm
by ralfpenkert
This happened a few weeks ago.
A rattling noise made me curious.
Opened the primary case and saw a lot of rolls broken.
Me lucky.
It was still running,
Ralf
Re: primary chain trouble VH 500,
Posted: Sat Sep 17, 2022 11:12 pm
by TonyBaxter
Are they the rollers from the centre of the chainwheel?
Posted: Sat Sep 17, 2022 11:39 pm
by Simon.Gardiner
Bits of broken roller from the primary chain. I've had one go like that, mine wasn't rattling - I think I might have found it when I was looking for something else. (Long while back, when the bike was the daily driver....)
Posted: Sun Sep 18, 2022 8:55 am
by daveleek
Ralf , that looks like a split roller chain , In the past I have returned chains with spit rollers even a cam-chain , Its asking for trouble using them , it looks like you have got away with it lightly
Posted: Sun Sep 18, 2022 9:30 am
by JohnnyBeckett
hi it looks like the wrong type of chain has been used not all chains a can take heavy loads
Posted: Sun Sep 18, 2022 9:32 am
by robjameson
I’ve known similar problems when people use industrial chains.
My local bearing supplier used to sell me this type of chain, which is far cheaper than an IWIS or similar but not up to the job. I only use top quality from the chain man these days.
Posted: Sun Sep 18, 2022 10:12 am
by Mick D
From the last image it's possible to see the rollers have fractured at two points, ruling out a split roller chain. It's more likely the result of poor quality materially or dimensionally - say a big 'thank-you' under your breath because you got away lightly and buy a Reynolds replacement.
Posted: Sun Sep 18, 2022 12:46 pm
by Eero.Korhonen
I am using motocross chain in my VH primary,
it is strong.
Br, Eero
Posted: Sun Sep 18, 2022 1:37 pm
by ralfpenkert
Thanks for comments.
I got this replacement,1/1" x 5/16", 73 links, roller chain, looks like Iwis.
Simply over the counter. A specialty store for chains and sprockets.
Will this one do it?
Ralf
Picture below shows the old broken one, can't read the make.
Posted: Sun Sep 18, 2022 9:47 pm
by klaus gerhard
IWIS chains have a good reputation. I am using them on all my Ariels after I had similar broken roller like you.
