Anyone using an Amal Concentric MK 1 ?
Posted: Wed Aug 24, 2022 8:48 pm
Well, having recently acquired a 1961 Arrow, it came fitted with an Amal 600 22mm dia series Concentric.
After trying to sort out the poor performance issues, I found out it indeed was a 4 stroke carb! So, I replaced the needle jet, main jet and also the
needle jet spray tube, to a sloped one, being correct for the 2 stroke application.
The idle jet is fixed with a tube insert, as found on 4 stroke carbs and is equivalent to a size 20 idle jet. I could drift this out and fit a 30 idle jet but the lean mix problem is 1/2 to 3/4 throttle, this would indicate the needle needs lifting or the needle jet needs enlarging. I changed the needle jet from 105 to 106 and tried a 107 but this was too much.
The engine is standard and is fitted with H.C. heads. Crank seals and gaskets good, no leaks. Compression cold 125PSI both barrels, standard gearing.
I have now got it as best as I can using the following;
Needle jet 106, main jet 150, middle groove on needle. If I lower the the needle clip to the bottom groove, the bike runs rich. Slide is No 3
Using 35 to 1 oil-petrol mix. Air filter Amal gauze type, nice and clean.
The lean mix is most apparent on going up hills, under load. I open the throttle and the bike runs lean, the engine slows and I have to change down, to third or sometimes 2nd and rev the engine hard. Top end is lovely and the spark plug checks, indicate a good burning process.
I think it may be down to the gearing of the bike, and could be a characteristic of the design. Can anyone verify this please?
It is different to any other 2 stroke I have tuned or ridden. It just does not like a quick throttle responses in the mid range.
I mounted a very cheap tacho which detects ignition pulses, this shows 6500rpm revs at Wide Open Throttle, Pic attached.
Any ideas would be welcome.
