Page 1 of 1
VH 1956 44-tooth primary chain sprocket
Posted: Wed Jul 27, 2022 6:21 am
by Philmynd
Wanted:
44-tooth primary chain sprocket for VH 1956. France, Acknowledgments
Re: VH 1956 44-tooth primary chain sprocket
Posted: Thu Jul 28, 2022 6:35 pm
by Philmynd
Hi Members,
I found the 3380-36 sprocket at Draganfly, but can you tell me where to find the center of this sprocket: 3380-05
Thanks
Posted: Thu Jul 28, 2022 8:37 pm
by JohnnyBeckett
hi you may get one from Greff brown at the AOMCC gearbox spares or try john budgen he has a lot of spares
Posted: Thu Jul 28, 2022 10:07 pm
by Simon.Gardiner
Philmynd wrote: Thu Jul 28, 2022 6:35 pm ....but can you tell me where to find the center of this sprocket: 3380-05
Phil:
For the Drags sprocket you would usually re-use the centre from your old sprocket (or a spare old sprocket).
Posted: Fri Jul 29, 2022 5:56 am
by Philmynd
It is really marked, the surface treatment has disappeared in places :(
Remanufacturing seems obligatory.
Philippe
Posted: Fri Jul 29, 2022 9:47 am
by Roger Gwynn
It looks good to me. If it is the centre where the bearings run that is of concern. It is really hard and not likely to wear as the bearing only operates when the clutch is operated. Any vertical movement in the bearing is usually cured by a new set of rollers.
Posted: Wed Aug 10, 2022 6:13 am
by Philmynd
Trouvé en Grece !!
Posted: Mon Aug 29, 2022 4:40 pm
by Philmynd
Toutes les pièces sont arrivées, remontage et essais
Posted: Tue Aug 30, 2022 10:27 pm
by JohnnyBeckett
hi when i rebuilt my gearbox and clutch i just fitted new rollers in the basket that i got from the clubs gearbox spares :D i have never needed to change the basket
Posted: Fri Sep 16, 2022 12:25 pm
by ariel.andersen
Hello.
I got this NEW OLD STOCK for sale.
If interest you are welcome to send a PM to:
<ariel.andersen@godmail.dk>
Jorgen
