Camshaft bushes removal
What is the best way to remove camshaft bushes heat case drift out with stepped drift or large socket head bolt draw out,similar to little end bush removal . Barrie.
Re: Camshaft bushes removal
Sorry, no answers. I only have an additional question on this topic, because I need to change the camshaft bushes on my NH as well. The bush in my timing case has an oil groove; the new bush from Drags hasn't. Should there be a groove?
I used a stepped drift last time I did one - on my W/NG. Hot case, if you have your wits about you you can do the main bearing at the same time.BarrieSteel wrote: ↑Tue Jul 26, 2022 10:01 am What is the best way to remove camshaft bushes heat case drift out with stepped drift or large socket head bolt draw out,similar to little end bush removal . Barrie.
