1948 Square Four
- robjameson
Re: 1948 Square Four
I’ve been making some really good progress with the square four. I’ve spent a lot of time cleaning up the engine and repainted the barrels and head.
Today was the day to fit the engine. Using an idea from a member I had seen elsewhere, I made a frame out of some wood, which made light work of the fitting.
I think progress will stall a little now, as I need to get the magdyno refurbished
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
- robjameson
Some of the parts of building this bike are a joy. Clearly the guy who built it last time knew what he was doing! Remote oil filter a very neat solution and something that usually involves a lot of head scratching when I need to make a bracket.
Unfortunately other things not so fun - rear wheel taper roller bearings are not in good condition. More expense. Does anyone have any feedback on the quality of ‘Timken’ bearings?
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
Rob - I'm not exactly up to date on these wheel bearings but I'm not sure there's much choice outside what Drags have in stock?
(http://forum.arielownersmcc.com/viewtop ... lit=timken)
Nice work, otherwise!
I wish I had a photo of that oil filter bracket when I built my 1937 Square Four. The arrangement on the 1937 bike is nothing like as good as that on the 1948 one.
Rob. Imperial sized bearings are about 4 times the cost of Metric near equivalents Timken are a good brand. If water is kept out they will see you out. Just pay the price and go onto the next problem. Nev
- Karol Burger
I still have some wheel bearings. I don't know how much a new van will cost. They are already quite expensive
https://www.arielklub.sk/inzerat-21358- ... 20-ni.html
- robjameson
Thanks Nev and Karol,
I have found some Timken bearings on eBay at a reasonable price and parted with the money.
Rob
Rob
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
- robjameson
Frustratingly, the bearings ordered appear to be a totally different bearing which has had a sleeve fitted to it. The sleeve is too small for the spindle and the rollers are much smaller than the originals.
So, they are going back and I will buy some from the vintage bearing company, which I should have done in the first place, since they are only 5 minutes away!
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
It looks like this sleeve in the new ones can be taken out?
but by the look of it you end up with a too big hole, hmmm, DIY new sleeve?
Nah, Vintage Bearings is better !
Rob,
When you refitted the engine using the wooden frame did you do it single handed or did you have a "glamorous assistant" to help?
Serious question - it looks like you need someone on either side of the frame to lift it in unless I am missing a trick.
