Page 2 of 4
Re: 1948 Square Four
Posted: Sat Nov 05, 2022 6:15 pm
by robjameson
I’ve been making some really good progress with the square four. I’ve spent a lot of time cleaning up the engine and repainted the barrels and head.
Today was the day to fit the engine. Using an idea from a member I had seen elsewhere, I made a frame out of some wood, which made light work of the fitting.
I think progress will stall a little now, as I need to get the magdyno refurbished
Posted: Tue Nov 15, 2022 9:42 pm
by robjameson
Some of the parts of building this bike are a joy. Clearly the guy who built it last time knew what he was doing! Remote oil filter a very neat solution and something that usually involves a lot of head scratching when I need to make a bracket.
Unfortunately other things not so fun - rear wheel taper roller bearings are not in good condition. More expense. Does anyone have any feedback on the quality of ‘Timken’ bearings?
Posted: Wed Nov 16, 2022 5:40 pm
by Simon.Gardiner
Rob - I'm not exactly up to date on these wheel bearings but I'm not sure there's much choice outside what Drags have in stock?
http://forum.arielownersmcc.com/viewtop ... lit=timken)
Nice work, otherwise!
Posted: Wed Nov 16, 2022 7:16 pm
by paul.jameson
I wish I had a photo of that oil filter bracket when I built my 1937 Square Four. The arrangement on the 1937 bike is nothing like as good as that on the 1948 one.
Posted: Thu Nov 17, 2022 4:56 am
by nevhunter
Rob. Imperial sized bearings are about 4 times the cost of Metric near equivalents Timken are a good brand. If water is kept out they will see you out. Just pay the price and go onto the next problem. Nev
Posted: Thu Nov 17, 2022 4:25 pm
by Karol Burger
I still have some wheel bearings. I don't know how much a new van will cost. They are already quite expensive
https://www.arielklub.sk/inzerat-21358- ... 20-ni.html
Posted: Thu Nov 17, 2022 10:54 pm
by robjameson
Thanks Nev and Karol,
I have found some Timken bearings on eBay at a reasonable price and parted with the money.
Rob
Posted: Tue Nov 22, 2022 9:17 pm
by robjameson
Frustratingly, the bearings ordered appear to be a totally different bearing which has had a sleeve fitted to it. The sleeve is too small for the spindle and the rollers are much smaller than the originals.
So, they are going back and I will buy some from the vintage bearing company, which I should have done in the first place, since they are only 5 minutes away!
Posted: Fri Nov 25, 2022 3:32 pm
by Vincent.vanGinneke
It looks like this sleeve in the new ones can be taken out?
but by the look of it you end up with a too big hole, hmmm, DIY new sleeve?
Nah, Vintage Bearings is better !
Posted: Fri Nov 25, 2022 10:20 pm
by andrewhawkswell
Rob,
When you refitted the engine using the wooden frame did you do it single handed or did you have a "glamorous assistant" to help?
Serious question - it looks like you need someone on either side of the frame to lift it in unless I am missing a trick.
