51 mk1 sq4 throttle cable
Posted: Fri Jun 17, 2022 8:57 am
I have noticed my throttle cable appears to be a bit short. When on full turn of handlebars it seems to pull the throttle on a bit. Not a big issue when riding as not using full turn. The cable run is as short as at can be (i think). I run standard bars and the correct cable for the bike, it is a mid adjust type.
Does anyone else have this problem.
Apart from that it runs well and I am just finishing off the heat cycle retorque proceedure, using those unbelievable but correct tourque figure.
