Are there any non-remote areas in Finland .
Its all remote from here .
Maybe not remote enough from Russia . . .
Fake HS?
- Bob.Murphy
Re: Fake HS?
Re: Fake HS?
You will be much happier with VH and HT.
I will send you a PM.
- seppo.seppanen
Re: Fake HS?
Yes. Plenty of empty areas with no-one even close. Luckily staying on west coast and not next to the eastern border...
1953 Square Four MK II
Re: Fake HS?
HS has a very small petroltank and uses much more petrol.
Re: Fake HS?
The HSMkI cam was a cast one, all other cams including the HS MkIII cam (which is hollow) are made from steel.
If it is possible / allowed to take the timing cover away + oil pump you could / should be able to see if it has a cast or a steel camshaft.
