Hi all,
Looking for the following parts for 1956 Square Four Ariel -
Right hand main bushes STD
Big ends .010 over size
STD rings
New oil pump
Inlet valves
Exhaust valves
Timing chain
4 Conrods (I hear they are making better new ones)
Thanks
Les Bowen
Wanted: New engine parts for 1956 Square Four Ariel
Re: Wanted: New engine parts for 1956 Square Four Ariel
Save your money on new rods fit a Morgo pump together with a screw on filter and use modern multigrade oil 20/40. Clean out the sludge traps on the crankshafts. Good to go on the bottom end.
The other items that you require can be obtained from Draganfly.
