Page 1 of 1
Is there an oil seal behind the crankshaft shock absorber on a 52 HV500?
Posted: Fri May 06, 2022 12:48 pm
by dennis.t
I cannot see one in the Drags drawings.
If not, what prevents oil seeping into the primary chain case?
Many thanks,
Dennis
Re: Is there an oil seal behind the crankshaft shock absorber on a 52 HV500?
Posted: Fri May 06, 2022 1:11 pm
by dave.owen
No oil seal
Posted: Fri May 06, 2022 3:21 pm
by Simon.Gardiner
dennis.t wrote: Fri May 06, 2022 12:48 pm ....what prevents oil seeping into the primary chain case?
Fit of spacer (behind sprocket) into crankcase is usually enough.
Posted: Fri May 06, 2022 6:50 pm
by dennis.t
Thanks both. I queried it because some Ariels of that vintage have an oil seal in that location. I have the sprocket spacer and it is a close fit so hopefully minimal leakage.
Dennis
Posted: Sat May 07, 2022 4:37 am
by nevhunter
There's usually NO problem there with oil seeping. Even if a bit did it would stay in the chaincase. Nev
