BSA A7 or Huntmaster? Crankshaft Identification Help Needed
Posted: Sat Apr 30, 2022 1:27 pm
by JimWalker
Re: BSA A7 or Huntmaster? Crankshaft Identification Help Needed
Posted: Sat Apr 30, 2022 2:24 pm
by simon.holyfield
Tricky to measure accurately, but if it's A7 it's 82 mm stroke and if it's A10/Huntmaster it's 84 (I think)!
As far as I know, most Huntmasters use the small bearing A10 crank; only the very last use the large bearing crank.
Posted: Sat Apr 30, 2022 2:52 pm
by Simon.Gardiner
By the shape of the webs and having the flywheel bolted on 'internally' with axial bolts I'd say that's not A10!
(Anyone thinking about a short-stroke 600cc Huntmaster maybe??
Posted: Sat Apr 30, 2022 3:20 pm
by simon.holyfield
Simon.Gardiner wrote: ↑Sat Apr 30, 2022 2:52 pm
Certainly doesn't look like mine!
Posted: Sat Apr 30, 2022 10:12 pm
by robjameson
Doesn’t look right for huntmaster to me, so most likely what it says on the tin!
Posted: Sat Apr 30, 2022 10:51 pm
by will_curry
I think it's a small journal A7 or A10. If so the timing side journal will be 1.375"
and the big end 1.46".
I've seen these cranks both with and without the chamfer on the outer edge of
the web. Chamfered cranks will fit either Ariel or BSA and unchamfered cranks
only fit one but I can't remember which.
Big journal cranks - 1.687" - have the flywheel secured with three bolts going in
from the circumference - if I remember correctly.
Posted: Sun May 01, 2022 12:22 am
by fpassmore
I agree A7, long stroke possibly, you need to measure stroke and journals then it becomes obvious. Sure looks the same as the one I just put in my ‘48 A7 LS.
Frank
Posted: Mon May 02, 2022 11:35 am
by simon.holyfield
will_curry wrote: ↑Sat Apr 30, 2022 10:51 pm
That’s right Will!
