My 1954 VH engine has an exhaust valve with a stem diameter of 0.375 (3/8") and an inlet valve with a smaller stem diameter.
I am suspecting that my exhaust valve is non-standard - can anyone confirm please?
54 VH Exhaust Valve Stem Diameter
- Ian.Cockshull
- keith.mettam
Re: 54 VH Exhaust Valve Stem Diameter
Hi Ian,
According to the measurements on the Feked.com site your exhaust valve stem has the right diameter for a '54 VH. The inlet valve stem is a smaller diameter at 11/32" from their info. See following links :-
https://www.feked.com/index.php?match=a ... 40&page=11
https://www.feked.com/ariel-inlet-valve ... 15-35.html
Regards,
Keith.
Regards,
Keith.
- Ian.Cockshull
Thanks Keith, that has set my mind to rest, never thought to look at the Feked.com site. Also it confirms that my inlet valve is correct too.
Best regards, Ian
Best regards, Ian
You could also refer to the table on the Draganfly site that lists all the Ariel and BSA valves with their dimensions. https://draganfly.co.uk/wp-content/uplo ... alves2.pdf
