Page 1 of 2
KH500 Wet-dumping
Posted: Wed Jan 19, 2022 3:07 pm
by JohnReilly
Good day all,
I ordered a supply-line anti wet-dumping valve from Deraganfly, when I received it I was a bit surprised as I was expecting a manually controlled shut off unit. The one received (picture attached) seems to be a "light flow restrictor".
My query is: has anyone experience using the valve illustrated and if so, does it do as intended?
Many thanks
John
Re: KH500 Wet-dumping
Posted: Wed Jan 19, 2022 9:28 pm
by David Smith
John
I use one of the Bri Tie anti wet sumping valves on my KH and BSA B31, they look a bit better made than the one illustrated.
They work faultlessly, but, they must always be sealed to the lines properly as any air leak will stop them working, AND must be primed before use, I pressure fed oil down the inlet pipe with a pressure oil gun on mine.
Dave Smith
Posted: Wed Jan 19, 2022 10:38 pm
by JohnnyBeckett
i use a valve that the will not let the engine start it the valve is not turned on, and when you turn it off the engine stops, i am not keen on the ones that use suction to work
Posted: Wed Jan 19, 2022 11:49 pm
by Roger Gwynn
Suck it and see if it works!
Posted: Thu Jan 20, 2022 11:45 am
by JohnReilly
Thank you for the responses, I will give it a go.
J
Posted: Sat Jan 22, 2022 4:12 pm
by robjameson
Norton Commando 961 models use a similar valve, but they have it on the return to the oil cooler before the oil feeds back to the frame. Works perfectly in that set up, but I’ve never tried one on the feed side.
I have the britie (I think) wet sumping valve on my KH bolted straight in to the crank case. Haven’t finished building the engine yet though…
Re: KH500 Wet-Sumping
Posted: Wed Jun 15, 2022 10:38 pm
by JohnReilly
I revert to this topic. Been away for 3 months and checked the bike, oil tank empty, contents in the sump.
I'm reluctant to insert any type of restriction into the feed line. Is the right solution a properly functioning oil pump or was it always thus, that wet dumping was a hazard even with the best workmanship and setup.
If I sent my oil pump away to be reconditioned would/could I expect a good result?
Posted: Wed Jun 15, 2022 11:32 pm
by Simon.Gardiner
To a great extent it's always been thus with any gear-type oil pump - why else would there be so many anti-wet-sumping devices about?
Overhauling the oil pump might fix the problem but that might not be guaranteed, although improving the condition of an oil pump has to be a good thing anyway?
Maybe consider one of these if the reluctance to put something in the feed line is the danger of forgetting to switch the feed 'on' when the engine is started
https://www.feked.com/anti-wet-sump-oil ... stems.html
(A friend bought a late KH from a long-time AOMCC member several years ago, it had something similar fitted and it seems to function just fine.)
HTH
Posted: Thu Jun 16, 2022 2:48 am
by nevhunter
Gear or trochoid pumps will let oil through unless there's no backlash at all and that's almost impossible. It depends on how the pump stops also that makes it vary. Good pumps leak less of course.. If you can start, idle the bike and it MAY return the oil before there's smoke everywhere. With regular use the problem may not exist but OUR bikes often sit for a while don't they? Nev
Posted: Thu Jun 16, 2022 2:30 pm
by robjameson
Well I have now got my KH up and running and 400 miles so far with no concerns.
Dad has the same anti wet sumping device on his KH and has had no problems in around 10,000 miles.
If you aren’t keen on the idea of a restrictive in the feed line, you could always go with the frankly genius idea of Richard Thomason of putting some electrical tape over the breather hole in the oil tank cap, which creates a vacuum and stops the bike from wet sumping.
