Page 9 of 21
Re: Hymn to the 1928 Model C
Posted: Wed Feb 09, 2022 2:32 pm
by Vincent.vanGinneke
On to fin repairing, always (well, to me) a bit of a nerving thing...
Made a set up with my pottery kiln and a electric stove to keep the heat in the cylinder while welding.
(electric stove I once liberated from the scientology church rubbish bin, but that's another story
cranked the kiln to 280 C. MIG welder on 6 with low wire speed.
No pics of the actual welding.... gloves to thick to push any buttons
Happy with the result after some grinding with the Dremel.
few nuts and a bit of tin sheet to get the position right.
(yes I did burn out the nyloc before work..)
post Dremel....
Posted: Wed Feb 09, 2022 4:42 pm
by Julian Murphy
Looks a neat repair.
Posted: Wed Feb 09, 2022 7:05 pm
by Karol Burger
I wonder if you will find a repair spot after the black paint
Nice work.
Posted: Wed Feb 09, 2022 10:08 pm
by Roger Gwynn
If I make it to the Dutch this year I will buy you a pint and you can tell me the story of liberating a kiln from the scientology church rubbish bin
Posted: Thu Feb 10, 2022 8:46 am
by Karol Burger
Posted: Thu Feb 10, 2022 11:43 am
by klaus gerhard
Vincent, can I join in with a pint to listen to the nice kiln story?
I will get a parcel ready for you with a few barrels where fins are missing. Once you now know how to do it!!!
Posted: Thu Feb 10, 2022 1:23 pm
Shall I let the tension rise and wait till the German rally or ....?
If I wait I'll have those beers up front, once those have settled in the tale only gets wilder
Or... It could be just another douchebagstory....
Klaus, funny thing with this iron welding..
If the parts are mine it goes o.k.
If the parts are not mine I'll fuck up and crack them
Posted: Fri Feb 11, 2022 1:28 pm
Gathered enough courage to tackle the cylinderhead now.
Fixed the two broken bits on the cylinderhead .
ready for the next step.
Posted: Fri Feb 11, 2022 3:28 pm
by cmfalco
Your repairs look great.
Posted: Sat Feb 12, 2022 10:15 am
by Bob.Murphy
I'm curious about this - are you MIG-welding mild steel repair pieces onto cast iron (or have I got it wrong)??
From what I have read and seen on 'You-Tube', it would be best to braze cast iron pieces onto cast iron because of the different coefficients of expansion between cast and mild steel (and MIG wire).
The repair does look good though.
