Page 12 of 21
Re: Hymn to the 1928 Model C
Posted: Thu Apr 28, 2022 11:53 pm
by Vincent.vanGinneke
Dents can be knocked out, so....
I've made up a impact slide hammer thing for inside the tube
calibrated ! o.k. maybe numbering it was over the top
Idea is to heat up the part in the handlebar's curve where the dent sits.
Hmmm, it works...sort off.
The rounded nose on the impact part needs some 'fine tuning'
ehhh, the one on the left it is.
Posted: Fri Apr 29, 2022 12:10 am
I wanted to grind in the seal between cylinderhead and barrel.
But...
a.t.m. head and barrel make contact on the outer rim.
And there is a gap between top of the barrel and head inside the combustion chamber.
So I made up a copper gasket to fill that gap .
Contacted Karol about it if this was a good idea, he told me yes.
But , how where these cylinderhead / barrel joints originally ?
If I use the outer rim as the seal, (which is wider then that inner rim) does that gap inside present a problem ?
Anyone any clue ?
Posted: Fri Apr 29, 2022 2:01 am
by cmfalco
Vincent, for what it's worth, the head of my 1928 Model C seats against the rim that projects from the cylinder/sleeve, rather than against the outer surface that you seem to be the case on your engine. This results in the ~0.007" gap that you can see in the photograph.
You mentioned in an earlier post that you installed a new sleeve, so it must project above the top of the fins by slightly less than the original one in my bike.
If it were mine, I would carefully measure the projection of the sleeve, and the depth of the inner ring on the head that should seal against it. The difference will be the height of the space between the two (I know that you know this). If you make a head gasket for the outer ring, no matter how thin you make it, it will increase that gap. My concern would be the sharp edges on either side of that gap might get hot enough to cause pre-ignition issues.
Ideally, I think it would be better to make a copper "head gasket" to sit on the inner ring, rather than seal the head against the outer ring. Depending on the height of the measured/calculated gap, this might or might not be easy. However, if the measured gap is small enough, Cu shim stock could be quickly and accurately cut with scissors.
Posted: Fri Apr 29, 2022 7:59 am
by adrie.degraaff
I have found prewar Ariels with both inner and outer copper gaskets, the fourvalve Ariel heads will brake if using the inner copper gasket due to the tension of the headbolts.
Posted: Fri Apr 29, 2022 8:51 am
Thanks Charles and Adrie for your comments.
I'll measure it all up and see if I can do this 'double gasket' version.
Must be pretty precise otherwise one of them hangs in there free.
This outer gasket is made by Karol and friends.
I'll make just a circle as the outer rim on the cylinder I have does not sit in the same level as the bolt hole part.
Posted: Fri Apr 29, 2022 5:03 pm
by cmfalco
Vincent.vanGinneke wrote: ↑Fri Apr 29, 2022 8:51 amMust be pretty precise otherwise one of them hangs in there free.
For exactly that reason I'd argue against a double gasket. Even if the face of the liner projection were
precisely parallel with both the inner and outer rings of the head, as well as with the outer ring of the cylinder, and you were able to make the thicknesses of both gaskets to within better than 0.001" of what they needed to be, would the "crush" of such thin sheets of Cu be enough to seal both rings through the full 360-degrees.
If the inner ring seals the interface between the head an projection, the outer ring does nothing, as evidenced by the fact I don't have anything on the outer ring of my engine. This also shows that an outer ring isn't needed to provide support since the cast iron is strong enough to resist bending. Considering all of this, along with the odds against all four surfaces being
precisely parallel with each other, and it suggests to me either only using an outer gasket and hoping there are no pre-ignition consequences of the resulting gap, or making an inner gasket and only using it.
Posted: Mon May 16, 2022 10:28 pm
Thanks Charles, inner copper ring it's going to be .
next question;
I am going to use the Amal pictured and want to fabricate a inlet manifold.
What is the distance from valve stem to needle on a '28 OHV ?
I have a alloy bar to make one from :
and : would it be o.k. to fit a fyber washer under the valve spring bottom collar?
I know they are used in alloy heads for quieter running, but does it make sense in a iron head ?
Posted: Mon May 16, 2022 10:59 pm
by Simon.Gardiner
All my iron heads (early '50s singles) have had hallite washers in the gasket sets (bought from Writers in the 1970s) to go between the valve spring collar and the cylinder head.
My understanding is that it's to do with reducing the heat fed back into the valve spring.
Posted: Mon May 16, 2022 11:31 pm
by cmfalco
To save wear and tear on your calculator, I held a somewhat flexible ruler with a metric scale against the spacer on my 1928 Ariel.
However, if you want more precision, the metal itself (not counting the gaskets at either end) measures exactly 1.250". The extra piece of metal next to the carburetor is a ~1.2 mm-thick drip tray from a BSA A10 to keep gasoline from falling on the magneto. I also extended the bottom end of that drip tray sideways to deflect any gasoline that might fall from the float chamber.
I don't know if my carburetor spacer is original, but it is the one that came with my bike and I have no complaints whatever with how the bike runs with it in place. Also, for what it's worth, my bike came without insulating washers for the valve springs and I didn't add any when I rebuilt the engine.
Posted: Tue May 17, 2022 8:09 am
Hello Simon, thanks.
Hallite, that was the name. I'll fit a pair.
To keep heat away from the springs, that's a very good reason!
I thought they where there because of noise, but that -ofcourse- is a 21st century approach
32mm for the manifold, and I'll have enough left from my bit of material to make another if need be.
thanks Charles .
That drip tray is also a handy thing..
