1929 LB250
j.coleman
1929 LB250
Post by j.coleman »
Hi, I know some of you thought it should go back in a skip, but I didn't & I bought it ! I was wondering if the engine and gearbox numbers match & what to do about the unreadable frame number if I Retube and repair it??? I remember a BSA in my ownership being x-rayed or something similar in the distant past to check if it was the original number. Can something like this be done these days??
Engine no is :- L1539
Gearbox is :- RPD3825
I know it will be loads of work but think its worth while.
j.coleman
Re: 1929 LB250
Post by j.coleman »
Sorry photos didn't download!
paul_turner
Re: 1929 LB250
Post by paul_turner »
If any one can Jim, then you can, I've seen the proof mate, good luck with it and well done for saving it.
paul.jameson
Re: 1929 LB250
Post by paul.jameson »
Look closely at the gearbox number. It should be RPD3823
Re: 1929 LB250
Wow! good luck and keep us posted!
a while ago I've seen a Black Ariel front fork spring in someone's stash.
If you need one I can ask , maybe send me some dimensions so I can check.
front spring.jpg (42.15 KiB) Viewed 1992 times
j.coleman
Re: 1929 LB250
Post by j.coleman »
Thanks Paul, yes I think you are correct
j.coleman
Re: 1929 LB250
Post by j.coleman »
And yes please Vincent the front spring is past it, I did have a spare but a guy here in Scotland needed it to get back on the road.
Paul_Linden
Re: 1929 LB250
Post by Paul_Linden »
Good luck and remember to keep the forum updated with news pictures, and progress on the rebuild.
Dave.Barkshire
Re: 1929 LB250
Post by Dave.Barkshire »
The world's undisputed expert on Colts is Roland Robinson so you might want to speak with him.
Re: 1929 LB250
Post by JohnnyBeckett »
hi i wouldn't like to risk my life on a frame like that :roll: unless you make a new frame then you are not saving a old ariel :?:
