Appreciate advice and experience on how to remove a very tight timing side retaining nut on the mainshaft pinion of a 56 VH. (The bike has been laid up in a shed for nearly 40 years and I am near the end of dismantling it, before restoration). I have tried to locked two nuts on the drive side shaft and use them as a means to apply opposite torque; however they move, rather than the timing side nut. My next thought was to apply some heat around the nut and shaft. All experience and advice appreciated.
thanks
Ian
How to remove retaining nut on VH mainshaft pinion
AOMCC # 1017
'52 KH
'56 VH
29/31VF
- keith.mettam
I guess you are aware that the half time pinion nut is a left hand thread, if I have read your method correctly Ian ? If you have the barrel off why not put a piece of wood between the flywheels to stop the crank revolving and then undo the nut ? If you still have trouble then get the gas blowlamp out and carefully apply some heat around the nut, it should move then with a bit of luck !
All the best with it,
Keith Mettam.
Keith Mettam.
I think you might have the problem identified, but if the nut is really tight you can drill a hole through it without damaging the mainshaft thread and then with a chisel carefully spread/split the nut. You do this with the shrink bands on car rear axles all the time. The gear is hardened but marking it a bit on tha face won't matter, Nev
