Fuel tap
Fuel tap
does anyone know of an ethanol proof tap to fit a leader?
Re: Fuel tap
hi if you know what sizes fittings it is go on Ebay and you will find one that is ethanol proof like i do for my motorcycles
Re: Fuel tap
the leader has an extended operating arm which is much longer than normal
Re: Fuel tap
hi ken , unless someone make one for your leader you will have to extend the operating arm , or you can try the club's two stroke spares he my do one or tell where to get one
Re: Fuel tap
Draganfly do an extension tap for the Leader and they also supply a neoprene 'cork' which is ethanol proof but a bit expensive and I've heard the corks are very tight so may need reducing down in size. Brian H. ps I've used corks in my taps for a number of years and not noticed any serious reduction in life due to ethanol fuel. The quality of the tap bore ie. damaged or rough ones seem to make the most difference.
