I've got an electronic regulator, the dyno works without a (working!) battery but it blows speedo bulbs (especially but not only LED ones).
Very bright lights though!
Dynamo
Re: Dynamo
Re: Dynamo
hi i have got a NH that was fitted a V-REG regulator when i got it, and will not run the lights without a battery when i got the ariel i got it running and the lights did not work until i put a battery on it and as far as i can work out it needs the power of a battery to make it work other makes of regs may work without a battery
Re: Dynamo
The regulator controls volts by regulating field current in the dynamo. IF it's adjusted too high you will blow small bulbs and maybe even bigger ones without a good battery in the circuit. You will also get excess depletion of electrolyte. Top up with distiiled water.(not acid) A dead flat battery is sometimes hard to get a charge started. IF it's been flat for a while it might be sulphated and may not recover. Nev
