Valve guides for MK2 sq4
I am looking for valve guides for a MK2 SQ4 ,Drags and Club spares dont have them ,would MK1 series B guides be suitable , PART NUMBER :- 477-50 which are available
Re: Valve guides for MK2 sq4
message SRM Engineering, they used to do them although they are mainly BSA , they definitely had some and oversized ones also
just google them, worth a try ?
An alternative option is to get guide liners fitted to your existing guides. I have used this successfully on my first Healey but the skilled man who did the job is, sadly, no longer with us.
Thanks Paul and Paul.J , I will look at SRM and enquire here in Holland about the liners,it is a bit hit and miss trying to find that skilled man , I have had a couple of misses just recently.
Can anyone tell the difference between MK1 series B valve guides 477-50 and MK2 guides I know valve stem size is the same ,so I was thinking I could have MK1 guides machined to size ,would this be possible?
Can anyone tell me the length of a SQ4 MK2 valve guide part number:--477-55 please
Hello Dave, I have an extra set of 477-55 valve guides if your interested. Gary
Hi Gary thanks very much for the offer , I have located a set , but if it falls through can I bare you in mind
No problem.
I have sent you a PM, Gary.
