Page 1 of 2
Charging problem?
Posted: Thu Dec 03, 2020 10:44 am
by Brian.Challinor
Hello, The problem I have is on start up the dynamo (c35sd) on my 51 sq4 doesn't seem do do anything until after about a minute of running it comes to life, I have to rev the engine and sometimes switch the lights on and off to get a + reading on the ammeter. I overhauled the dynamo during the rebuild. I have a new battery fitted and use a DVR2 regulator. After the dynamo kicks in it charges ok, but I have to go through the same sequence on initial start up. I'm thinking the field coils are weak.
Re: Charging problem?
Posted: Thu Dec 03, 2020 2:20 pm
by JohnnyBeckett
hi have you made sure the dynamo has got a good earth and all the earths on the bike and the regulator can some times be a bit lazy to start up
Posted: Thu Dec 03, 2020 6:52 pm
by Brian.Challinor
Thanks for reply, I will check earths but I think they are good.
Posted: Thu Dec 03, 2020 9:39 pm
by JohnnyBeckett
hi Brian have you check the volts at the battery with the engine running, my 6v is showing 7.2 volts with the engine running but no Amps till i rev it or ride it then it shows it charging i put it down to the new type of regulators
Posted: Thu Dec 03, 2020 10:30 pm
by Brian.Challinor
Will check tomorrow, the bike runs a bit rough until it starts charging, then its fine.
Posted: Fri Dec 04, 2020 11:46 am
by admin
My magdyno dynamos do this.
The electronic regulators, fitted inside the original reg boxes, seem to want a bit of current (generated by revving ) to wake up.
Posted: Fri Dec 04, 2020 12:00 pm
by Brian.Challinor
The reason I posted was because I don't like revving the engine from cold. Its made feel a bit better knowing that its a ''problem'' with the regulator and not the dynamo probably.
Posted: Fri Dec 04, 2020 12:31 pm
by chris.shearwood
You can run a wire from the Dynamo wire to the Field wire with a momentary switch in the circuit. Touching the switch should be enough to wake up the regulator. A bit of a bodge but what the H***
Posted: Fri Dec 04, 2020 6:02 pm
by will_curry
The problem is a function of the internal resistance of the electronic
regulator. Chris's fix works by by-passing the regulator momentarily.
Posted: Sat Dec 05, 2020 12:58 pm
by Brian.Challinor
Heres what the makers hd to say
