Ariel 4F/600 - 1932
- Karol Burger
Re: Ariel 4F/600 - 1932 engine
it was relatively easy to disassemble. I found that the previous owner neglected the quality of the work and also used very damaged valve guides. some of them were broken off maybe half an inch but I only found out when I removed the valve spring
- Karol Burger
I had the engine head sanded today and checked for errors. it looks good. On Monday, we will bring it to the alignment of the seating surfaces. I cleaned the moving parts and except for the two valve guides, everything is fine.
forgive me my English. I don't know a word, I use a translator
- Karol Burger
the upper aluminum head box has many flaws. Fortunately, I have one spare. Repairing damaged parts would take me a long time. I'll put it off until later, for another engine.
- Karol Burger
Have you ever used the original guides and valves back into the engine being repaired? I have enough of them and they seem to be good.
Before you refit the rocker box, check that the threads in the cylinder head are good for the 4 studs which hold the rocker box lid on. I missed this when fitting a replacement head on my OHC four and suffered an incurable oil leak as a result. Incurable, that is, unless I took the valve guides out again which is not something you want to do.
Karol - you have an extremely good translator!Karol Burger wrote: ...forgive me my English. I don't know a word, I use a translator
Originaly the head bolts press on the aluminium rockerbox, that is not good, here they are making steel inserts with a viton O washer so the headbolt is pressing on the head and sealing on the rocker box.
I can understand that it dus not feel good to make the rockerbox holes bigger but this is needed to make a good cammy.
- Karol Burger
thanks for the info, i'll have to check it all out. I hope that my head will return straight tomorrow and I will be able to continue the repair
- Karol Burger
The engine head is ground on both sides. now there will be less risk of oil leakage and damage to the Head Gasket
- Karol Burger
the seating surfaces must fit evenly at all points. tomorrow we will prepare the head for painting
Users browsing this forum: Ahrefs [Bot], Les H, roland robinson and 19 guests
