Ariel 4F/600 - 1932
- Karol Burger
Re: Ariel 4F/600 - 1932 engine
New bearings have arrived, I will be able to fold the crank
- Karol Burger
I had the auxiliary rings blackened. Now I can start folding the crank
- fpassmore
Very nice work Karol. Keep us informed as work progresses and the pictures of the work are first class.
Frank
Frank
- Karol Burger
Today, cranks are assembled. I will try to center them at 0
- Karol Burger
I managed to center all important points at 0. I added connecting rods and put everything in the prepared crankcases.
- Eero.Korhonen
That is impressive work, well done.
Br, Eero
Br, Eero
- Karol Burger
demonstration of their work
- Karol Burger
together with the Ariel 4F / 1932 engine I also started to renovate the 4F / 1934 engine
I sent him to an aluminum cleaning company. The result is wonderful
the total cost of cleaning did not exceed EUR 75 www.cistenihliniku.cz
- Bob.Murphy
Nice work . . . LOVE that Surface Plate .
Impressive work. When assembling the big ends, it is worth rotating the con rods by hand for a few rotations. The rollers have a tendency to bunch up and prevent rotation if you don't have enough clearance in the big end bearing. Rotating the con rod with a finger will test this. If the rollers lock up, the bearing centre will turn on the crank which is a common problem on the ohc four engine. You need to be able to put a 1.5thou (0.0015inch) feeler gauge between the rollers and the outer race to avoid the rollers locking up. Information courtesy of the late Ted Woodrow (who built the replica of Ben Bickell's blown OHC four) and tried and tested satisfactorily for over 10,000 miles on my own ohc four.
