ariel square four mk2
hi guys
I have a mk2 that I rescued and I have an issue. although I have had it running , I fitted electronic ignition [ just the points] and I cannot get it to run again , originaly the unit failed , and got it swopped by dragonfly , my question is --is there anyone in sussex that can tune it for me , advancing years have caused a problem with kicking , originaly after the first re-build I found that it started first kick --now it hates me
hope you can help
hope you can help
Re: ariel square four mk2
Hello mate, i'm a new member just joined 6 months ago, January 2020 and saw your post, i'm having same issues very very frustrating- 1955 mk 2 new loom, new IGN 15 from Drags, new everything, no spark, no spark.... how did you get yours to run please?
Leon
Leon
hi I set it as manual --tdc ---etc etc ---fired and ran --then made a high pitch noise --never to go again ---drags changed the unit u/g I am looking into a accuspark distributor at $150 seems the easy way out , its difficult to know --accuspark do recommend using a non copper ht lead ,
regards
allen
regards
allen
- Paul_Linden
I have an Accuspark distributor on my square four and am very happy with it. As you say, you should use silicon carbon HT leads with it. Make sure you get the right polarity and the right rotation (clockwise when viewed from above). But note that you will have to adapt the advance retard unit to be correct for a square four.
I have a Powerspark (= Accuspark?) distributor on my Healey Square Four which was difficult to time but is now working well.
Leon - I have sent you a Private Message.
many thanks for your message Paul, since i'm not a computer guru, am trying to retrieve it but no luck. any advice please?paul.jameson wrote:I have a Powerspark (= Accuspark?) distributor on my Healey Square Four which was difficult to time but is now working well.
Leon - are you having a problem locating the 'Private Message - Inbox' area of the forum or have you navigated there OK but can't see any messages??
Hi Leon
Did you recover the PM ?
We're having problems with forum notifications (still), but forum messaging should work (it just won't email you that a message has been received)
Administrator
webmaster@arielownersmcc.com
hi
can anyone reccomend an engineering company to work on my square four please
regards
allen
regards
allen
- Paul_Linden
Allen, have you tried Draganfly? If they cannot do it they may know someone who can. Regards, Paul
Users browsing this forum: Bing [Bot] and 12 guests
