REAR LIGHT WIRING
General electrical problems
REAR LIGHT WIRING
Post by JohnnyBeckett »
Hi All how does the rear light wiring run from the rear light to wear it joins the loom how does it run up the mudguard and what does it fix to on a 350 NH 1954 with swinging arm :?: :?:
Re: REAR LIGHT WIRING
I believe the original guard on my FH has clips to allow the cable to sit in the rib. There's a gap over the connection bridge for the cable to go through.
HI Simon is these clips part of the mudguard and do you mean the connection bridge that joins the two parts of the mudguard together :?: and does it have a join in the wiring wear the two parts of the mudguard join so wen you remove the rear half of the mudguard so the wiring comes with it :?: thank you for the post TAKE CARE
Mick D
Post by Mick D »
Hi Johnny
A couple of photos to illustrate what Simes says:
Rear Loom Route 2.png (158.31 KiB) Viewed 2326 times
Yes I have kept the break in the loom to allow the rear section of the mudguard to be removed, hard wiring from the light to the break at the mudguard join and adding a dedicated earth running from the light to an earth collector point at the regulator.
Well done Mick - I got distracted repairing a mulcher yesterday!
Last edited by simon.holyfield on Thu Jun 04, 2020 11:45 am, edited 1 time in total.
HI Mick and Simon my mudguard has not got clips to run the wiring under the mudguard i will have to weld some on it to fix the wire to and is the joint in the wiring under the mudguard :?: my wiring was just run from the back of the light into the mudguard then across to the frame where the shocks mount and along the top of the frame and it look like a right bodge :( :? thank you for your posts and KEEP SAFE
