Ariel 350 1947 hard to start?
My ariel which I have just purchased is very hard to start. I have put a new lead and plug on which helped a little but is still very difficult. Is there any other things I need to adjust or replace?
Wayne Martin 1934 twin port VH, 1927 Model E Supersport,1959 Triumph 5TA Bobber,
- Steven.Carter
Here's a few things to try. Are you tickling the carb, how have you set set the advance retard leaver? Should be around 1/3 towards fully advanced. Points gap? Good compression? . When kicking bring the piston up to compression then just use the valve lifter to bring the piston over top dead centre. Close the valve and kick.
Or failing all the above, consider the bike scrap and give it to me
Steve
Steve
Or put another way ...
Bike in neutral
kick it gently until it get's really stiff (coming up onto compression)
Now either carefully push it JUST over compression or pull in the lifter/decompressor and JUST move it over.
Now tickle the carb which WILL leak.
Move the advance/retard lever a third to halfway
deep breath and a determined kick
EVERY BIKE IS SLIGHTLY DIFFERENT IN WHAT IT LIKES; it will take pactice to figue it out.
If it's a no go, after a few goes, then pull the lever all the way to advance and do the same again but get your leg off the kickstart a quick as it may knock you back.
It should bang/huff back through the carbuettor; which is a sure sign of of over advance and a spark (good thing). My bikes usually start after that.
If you can repeatedly kick it on full advance, without any if this, then it's either not sparking or the timing is way out.
You can always pull the plug after exhausting yourself kicking to see whether it flooded (very wet plug).
Bike in neutral
Administrator
webmaster@arielownersmcc.com
Following on from the measured, quality answers above, if you have the technique right, then it's always one of 3 things;
Compression (you have said it's OK)
Fuel - starvation (blocked jet) or flooding. Is there crap (dirt, rust) or water in the bottom of the carby? Does the bike idle well when it does start?
Spark - is there a good bright spark when you ground the plug? - could be weak magneto, HT pickup dirty, dirty points.
Do you have the timing right and the points properly gapped?
Other than that, there is always Steve's final solution...
Good luck, Brenton
Good luck, Brenton
The 350 is heaps easier than a 500 to kick start. Generally the magneto is the first thing to check if the bike doesn't fire or kick back. ( as others have said). Check thet the points are clean and open up to about 018". Magneto's aren't the troublesome things that some make them out to be, but they have to be right. If theyare on the way out they usually fail after about one and 1/2 hours riding. It's hard to check the spark when the mag is in the bike, but if you can have the plug on the end of the lead and get another 1/16" extra spark with a brisk kick it should be ok for starting. happy riding Nev
A sure fire way of starting any petrol motor [with spark] is some starting spray.Mixture is not critical,and once going,you can adjust the carby properly.Make sure there arent any high impedance components in the ignition,these wreck old maggies very quickly.Best test all components with an ohmmeter if youre not sure.Even sparkplugs can be supressed,but theyre usually marked.Regards John.
- john.nash
Re:
You probably don't want a suppressed plug cap or a plug with a resistor ... (NGK plugs with an R in their name)john.whiting wrote:A sure fire way of starting any petrol motor [with spark] is some starting spray.Mixture is not critical,and once going,you can adjust the carby properly.Make sure there arent any high impedance components in the ignition,these wreck old maggies very quickly.Best test all components with an ohmmeter if youre not sure.Even sparkplugs can be supressed,but theyre usually marked.Regards John.
This is a very VALID point. Most leads are high resistance "suppresson" leads and the magneto doesn't like being open circuited on the HT side. It tends to force a short circuit in the windings. Use a copper wire cored HT lead. Shorting the plug out doesn't hurt it at all as you would notice with many stationary motors which are stopped by earthing the plug terminal with a spring steel tab. "R" plugs are not recommended either. (As stated by John/ John, for the same reason. Nev
