Can anyone provide intel on the crankshaft gears TDC marks as well as the camshaft mark.
I have the #1 piston at TDC and the markings make no sense. Thanks, New guy
53' Sq4 timing marks
Re: 53' Sq4 timing marks
Hi Gary, if you check out two posts in this section of the forum by Adrian Hannam over the last few weeks you'll get some ideas.
Waller's info is available in the Knowledgebase if you're a member.
Thanks Roger
