1930 rear brake lug on frame
Hi would anyone know how far the lug on the 1930 frame is [ or have a photo of it] , to lock the brake plate in please.
Re: 1930 rear brake lug on frame
I have a 29 frame if that helps.
Hi again Andy, any chance you could measure the length and diameter please?
Second picture is where the lug should be, starting to breath some life into the old girl now.
- barry.swanson
...hi Mike, I have a '29 and a '30 frame to compare...the rear frame lugs are quite different castings and as a result the brake plate anchor pin lengths are also different ...your '30 pin is 5/16" OD, and protrudes 5/16" inside the frame lug . Interesting to note he '29 item is screwed throught the lug with a nut on the outside...not sure whether your '30 item is screwed in or brazed, someone else might be able to advise on this...Barry.
Users browsing this forum: Ahrefs [Bot] and 23 guests
