Mk11 distributor duplex drive gear
Hi guys and dolls looking for a Mk11 distributor drive gear duplex drive will also purchase the complet distributor. Drags on back order and the weather is starting to become warmer? Cash is waiting and thanks for looking . Keith
- Paul_Linden
Re: Mk11 distributor duplex drive gear
Keith, assuming you mean the 12 tooth gear (the one drags lists as 220609) on the bottom of the distributor then it’s worth checking car autojumbles as the DK4 type distributor was fitted to several cars, like some Austins. It’s highly likely that Lucas used this gear on other distributors. Unless someone knows for sure it was only on a square four mark 2?
- Paul_Linden
These look possible
https://rover.ebay.com/rover/0/0/0?mpre ... 3771003231
https://rover.ebay.com/rover/0/0/0?mpre ... 3334535850
There are more there
Keith have you tried club spares, Bruce Longman normally has the matching pair in stock, always try club first,
Cheers Paul I no Bruce has not been in good health recently. I will try him and get an update on he's health progress. Keith
Hi Paul thanks for those links, not sure how many teeth on my distributor. Have not got one to check, do you happen to no the the teeth number please mate regards Keith
Paul wher did you find the that Mk111 I think Ariels only made 2?
Would love to see some picture's regards keith
- rein.heerkens
Send you a private mail.
- Paul_Linden
Hello Keith, my Mark 3 is just a square four engine in an Ariel swinging arm frame that was a home build. I believe that Ariel did have a prototype mark 3 square four that had swinging arm front suspension, and the mark 4 would have been been telescopic front and swinging arm back.keith wainwright wrote:Paul wher did you find the that Mk111 I think Ariels only made 2?
Quick update is that I’m now running it with a concentric carb while I refurbish the Solex (again) and have fitted a kill switch in case the carb slide sticks open. I’ve also fitted a tacho, but more of that later. I took it for a spin yesterday, and it was running fine, no more snagging tasks. I got home too late to take pictures, and today storm Ciara is blowing through, so I’m bunkered down in the shed.
I can post some new pics next weekend when I plan a longer ride. Being in full time work is limiting for many things.
Hi Keith, the gears vary according to whether you have simplex or duplex timing chain.
