engine and frane numbers
Re: engine and frane numbers
Hi All
The frame in the photo has no numbers on it . I am also looking for a gearbox bearing W6501 30mm bore 21/4 OD and 7/16 wide I hope someone can help
Steven
Steven
The frame number is on the upper horizontal part of the lug in the last photo. The prefix shall be J.
This is a frame in a friends loft we have looked in the usual spots. Vertical under the seat there looks like an N but not sure. the frame has been added to for another motor I can try to get some better photos to in a day or two still looking for gearbox bearing.
Steven.
Steven.
Great to see your making progress Steve. It will a very nice looking bike when done.
My frame number is located just under the seat and it starts with N, then again yours should be J.
Hi Ian,
This is a new old frame in a friends loft not mine
Hi Steven,
the 50th Ariel Colt have the same gearbox bearing. Part-No. 12426-54. Draganfly have this bearings on stock. I use the same in my 1930 LF.
http://www.draganfly.co.uk/index.php/ac ... duct/1485-
Regarts Stefan
Regarts Stefan
Thanks
Bearing is in order things are going slow this work thing keeps getting in the way.
thanks to everyone for your help but work is still getting in the way.
I am still looking for some parts
Burman gearbox cover plate 70R 88-89 mm
the speedo drive 98R
the kick start return spring 63R
the kick start center pin 125X
the kick start arm
I also need the bottom anchor for the fork spring
And I must say THANKS VERY MUCH to ALBERTA SPRING Graham has gone well out of his way to help me with making the new spring
Steven
the kick start arm
Steven
Hi All
Vacation time is getting close and hoping to give some time to the 31 I am still looking for some gearbox parts. It looks like the RP gearbox was only built for 4 years if I cant find the parts can anyone tell me the next best box to put in
Cheers Steven
Cheers Steven
NUTS AND BOLTS
I am looking at putting in an order for some nuts and bolts. Does the club have someone to use?
