engine and frane numbers
Re: engine and frane numbers
Ian Taylor in Canada lives not to far from me and has already offered me lots of help and we will try to hook up in June at a rally
Cheers Steven
Cheers Steven
I don't see the clutchlever-speedodrive-deck but that's not a problem becouse i have one for you.
I will need to take a good look when it gets delivered should be mid week
HOLY CRAP
what have I done the bike /parts are home I will try to send Frank some photos.
- fpassmore
Here are a few more pictures from Steven
- fpassmore
and some more !
- fpassmore
one more set
Should keep you busy for a couple of weeks.!
1958 Huntmaster
1960 Matchless G12
1958 AJS 18s
1960 Matchless G12
1958 AJS 18s
That's a nice pile of bits you have and in what looks to be in very good useable condition,you should get it together quite easily,they are a nice little light machine.Good luck with it.
Well I have started to go over some parts and dry fit some parts. I do not have the front fork spring or the kick start arm I will also need the outer case for the speedo cable. I have found both inverted levers most of the gear box parts. All I need to do is fine out what bolt/nut goes in what location.
Any help or advice would help alot
Cheers Steven
P/S If its ok with Frank I will keep sending photos
Cheers Steven
