Page 3 of 4
Re: sq4 solex-bi-starter
Posted: Mon Dec 11, 2023 6:15 pm
by simon.holyfield
Henning G wrote: ↑Mon Dec 11, 2023 6:01 pm
Just discovered that my pilot jet is too high, so the float chamber cover "rides" on the pilot jet .
Picture? Sounds like that would lead to an air leak in the pilot circuit.
Posted: Mon Dec 11, 2023 6:43 pm
by Henning G
Absolutely right, that’s really bad. I guess that the fuel camber and fuel camber cover should be a tight fit to create the necessary vacuum for the idle system.
by Henning G
the drill is slightly over 2,5mm
Posted: Mon Dec 11, 2023 9:29 pm
by chris.shearwood
I can put a .113 inch (2.87 mm) drill bit into the hole in that jet on my Solex bi-starter.
Another place you might try to find jets is:
https://classiccarbs.com.au/index.php?r ... y&path=261
Here is a scan of a page of Ariel The Post War Models by Roy Bacon on which I have written the Solex part numbers:
Posted: Tue Dec 12, 2023 5:34 am
by Henning G
WOW, that’s great, Thanks. I wonder how big influence my faulty Air Correction jet will have on my Idle, should be a 150 jet, mine is 120..
Posted: Tue Dec 12, 2023 6:58 am
by Henning G
My pilotAir Bleed jet is 150, correction jet 120, is that way out..
Posted: Tue Dec 12, 2023 8:33 am
by simon.holyfield
I thought the air correction jet was supposed to emulsify the fuel coming into the main choke, not the idle supply. I think it would make the bike run rich overall wouldn't it?
Posted: Tue Dec 12, 2023 10:42 am
by Pete.Silson
Both the
Air Correction Jet and the
Pilot Air Bleed should be 150 (1.5mm).
The tickover mixture is governed by the ratio of the
Pilot Jet 070 (0.7mm) and
Pilot Air Bleed 150 (1.5mm). The tickover mixture is further adjustable using the
Volume Control Screw - clockwise for weaker, anti-clockwise for richer. The tickover
speed is adjusted by the throttle stop on the main butterfly.
The ratio of the
Main Jet and the
Emulsion Tube controls the mixture over the whole rev range. The
Air Correction Jet has more influence at higher revs.
Posted: Tue Dec 12, 2023 12:31 pm
by Chris Sealy
I use Mikuni for the main jet, 120 with a 5mm thread; and the air correction jet 150 with a 6mm thread. There may be other jets that will fit or could be adapted to fit, but my experiments have not gone that far yet.I have found genuine Mikuni jets to be very accurately made, unlike some of the genuine Solex jets that I have come across. Mikuni were agents for Solex back in the day and some of their jets are still identical today.
Posted: Tue Dec 12, 2023 12:37 pm
by simon.holyfield
Chris Sealy wrote: ↑Tue Dec 12, 2023 12:31 pm
That’s really useful,thanks Chris.
