Seems to be fine at the moment Reg, but then the engine is still in pieces so this machine has not run yet. I plan to use a section of a Metalastik suspension bush - from a Land Rover, Morris 1000 or similar, cut to length to form the cushion element.Reg.Webster wrote:Hisimon.holyfield wrote:In my blog post 'spend a night in the box' there are some views of the kickstart stop.
Did your new kickstart stop peg, work ok I.E. no loud clanks etc when releasing the kickstart, or damage to the mechanism not having a buffer to hit rather than solid metal.
I have to make a choice of doing something similar to you or buying a box (allegedly working fine) I have been offered for £100.00
Is this the going price for a box ?
Thanks
Reg
kickstart and Speedo problem 1946 4G SQ4
Re: Re:
Re: Re:
Johnadmin wrote:Is that a BA box ?Reg.Webster wrote: I have been offered for £100.00
Thanks
Reg
If you didn't want if, for that money, then I would![]()
Not exactly easy to find, complete ...
baought the BA box (G106D50) for £100.
The story is it was with an old Norton from America instead of a Norton box so was not wanted, just need to strip it and make sure it's not an empty box (feels heavy)
Reg
